Discuss Does tile mister delta board need priming in the Canada Tile Advice area at TilersForums.com.
I'm with you unless it says under no circumstances what so ever do not even think about priming it , I prime everythingPrime everything unless spec says not to and so far never seen anything say not to, always a first though
Thank you for the replies.
Instructions doesn’t say primer is needed. Nor do they say not to it
I have heard the same of jackoboard as wellMy understanding is that Delta boards use a weird type of cement face (from Tilemaster) which only finally cures in contact with water in adhesive.
In other words, priming it will make a weaker bond than not priming it.
I know it sounds stupid but thats' what I've heard from Tilemaster.
(Personally though, I prime everything)
Reply to Does tile mister delta board need priming in the Canada Tile Advice area at TilersForums.com
