Discuss dot and dab and bath position question. in the Canada Tile Advice area at TilersForums.com.
yep, it's the only viable option I think Mark, one of those that are dome shaped at the back would do it I reckon.As you 5mm is not enough especially with an acrylic bath, have you mentioned the thought of changing taps....
in all fairness Rob, that was my first thought, but if plumber had brought it forward anymore it would've been into the curl of the bath wall. With hindsight it maybe should've been situated in a corner rather than on the length of bath.the tap has been drilled in the wrong position
Can the tap be removed and hole elongated at all...if the base will cover of course ?
Min 20% of the surface area of the board, I think!just intrigued to know from a pro plasterer what the minimum amount of dabs would be, is there a recommended minimum?
Reply to dot and dab and bath position question. in the Canada Tile Advice area at TilersForums.com
