brian c
Good to see you backtracking big man...lol
i have wondered about this for quite some time , plaster board is fixed with dry wall adhesive spotted on the back and banged back flat with a straight edge does this mean that the dry wall adhesive (GYPSUM BASED) has a greater bond strengh, loadbearing and shear strength than tile adhesive (CEMENT BASED)? will one of the adhesive technical guys please explain as the front of the plaster board we are lead to believe holds 32kgs per sq m which has to be solid bed which spreads the load but the back of the plaster board can take all the weight on a point load with gypsum based adhesive ?hi all heres a thought tilers need 95% coverage of adhesive .plasterboard can be dot and dab .that makes sense:8:
