dot n dab backer board onto brick
JMC tiling
Evening all.
Got a job where I have to dot on dab some tile insulation backer board onto brickwork to build them out to the same depth as the existing plasterboard. I am going to mechanically fix them aswell but wanted to know whether to use plasterboard adhesive or tile adhesive on the wall (wall will be primed).
Cheers
As above.
I used these things a while back when fixing 30mm boards to blockwork. Very quick and easy to use.
C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_Plastic_Cobs.jpg
JMC tiling,
hmtiling,
JMC tiling,
hmtiling,
