Discuss dot n dab boarding.... in the Canada Tile Advice area at TilersForums.com.
How so Ali? Nailing is much faster IMO
Screwing is the prefered method because of less movement as Neal says. If you've had to repair as many skimmed walls as I have where the plaster has popped over the nail heads you'd agree Wilder
Nailing is hardly a bodge but screwing is much better
Bag of board addy £4.80..... Bag of tile addy £11 ..... Now what was the question again?
what is the correct method of dot n dab boarding onto plasterd wall... Currently in the process of doing me moms bathroom. Ive moved the bath over and there is a gap either end and a 12.5 mm board either end will sort all my problems... I plan to prime the plaster, board and then tile.... But can I use the adhesive I plan to use for the tiles or do I need drywall adhesive? and if my method is incorrect please let me know cheers.
Reply to dot n dab boarding.... in the Canada Tile Advice area at TilersForums.com
