Dry cutter thread....for use with polished porcelain
Was told by the Sigma rep to use Silicon spray to lubricate the rail............. who knows best?
Well Tom I can confidently speak from much experience from many accumulative decades of experience from a large team of tilers and conclude that if you lubricate the rail it becomes a dust magnet because of its surface area.
In general your tile cutter isn't very far from dust, either from mixing, grinding or brushing up etc. When that dust finds its way to a moist area it will stick like you know what and will soon clogg things up and to the inexperienced user it can appear that the machine isn't working properly and they mightn't know why and may assume their tool is goosed.
There's no question that a freshly lubbed machine will glide like a dream, but in reality that doesn't pan out so well in everyday use.
In my humble opinion the advice I've gave above is without question in practice the best way to maintain a Sigma!
Also told the same by sigma rep
I'd like a chat with the Sigma rep that said that!
In all their instruction both documented and machine stamped it clearly states where to lubricate, nowhere does it say to lubricate the rail and also in reality it doesn't work!
Thanks chaps - I have to say this has to be one of the friendliest forums I've been on in years! Such a nice change as a lot of trader sites you are met with 'get someone in that knows what they are doing' brigade which kind of goes against why you are researching. I'm kind of getting the idea how good these are now and thanks for the maintenance tips! (I can see why you wouldn't oil the rail - precision items, clean etc) 🙂 I do look after my tools and the likelihood is that this won't be sold given it's usefulness. Guess this will be ok hung in a sealed unheated garage? They aren't prone to pitting are they?
I suppose where I was coming from on resale was that i can't get my head around why someone wouldn't pay £40 extra and get a new one, but if they really do last like people say... why bother... and like you say, if heavily used, the price reflects the 'still' usefulness in the cutter.
PS I was looking at Rubi, but apparently the TS isn't up to Porcelain (different views on this but manufacturer says ceramic only), and the TX costs quite a bit more than the Sigma I'm looking to buy - why would i pay extra for a TX?
PPS This might be leading to yet another new tool - Whilst so far successful with the likes of metro tiles, I don't think my Plasplugs wet cutter is going to be up to the job in cutting porcelain, more because of the depth of the tile (10mm) leading to chipping....
On a side note and totally unrelated - what do you chaps do with the electric floor mat heated cold/hot feed bulky connection that's advised to sit beneath the floor boards, encapsulated in adhesive? I've made a gap in the wall where i was going to fill with adhesive and tile over, but since it is prone to overheating and reducing the life of the mat, am i best cutting a hole in the floor and letting it 'dangle' beneath? Surely this would be a better way to prevent overheating?
I came very close today to spraying wd40 on the rail but it was just a burr on the rail so a light rub with sand paper and it was great again. I cut a 20mm piece off a 900 porcelain plank today as well, brilliant!
With regards to the chunky wire you speak of, that needs to be covered fully in adhesive or leveller, then a tile. Usually make a recess in the insulating board to sink it in a bit to avoid excess height build up
I'll hold my hands up and admit I spray wd40 on mine all the time.....and Lee is correct it dose clogg up and make it stiff to use....but I just spray more wd40 on it and it all loosens up ....been doing it for years and as yet it works fine.
Mind you my cutter's are over 20 years old.....testament to how well they last !!
I'll hold my hands up and admit I spray wd40 on mine all the time.....and Lee is correct it dose clogg up and make it stiff to use....but I just spray more wd40 on it and it's all loosens up ....been doing it for years and as yet it works fine.
I was told that wd40 is incorrect to use as a lubricating spray as IT WILL attract dust and grime, so eventually clogging up but if you use a Silicon spray, like this one, LINKY, it shouldn't clog up as much.
1animal1,
Old Mod,
1animal1,
Old Mod,
