The LPO was signed and issued to the ceramic tile contractor, so cost and time savings is not the issue. LPO was issued for concrete screed. This one i believe in, since a concrete surface is reliable against earth shifting and causing movement in the soil, and it is just plain stronger.
I was simply inquiring on others' professional opinion, on the strength of this method of dry fix, and if you felt i was able to reduce the payment for less, since the dry fix, in my opinion, isn't stronger, and takes far less time to install.
Also, logic tells me, that this method would only be believable, if i saw the installer doing a concentrated effort at compacting the soil, and, based upon the situation of the install, and please correct me, but it seems there should be a minimum of 75 mm of dry mix sand/cement material, to have something to compact, because i'm sure it must be difficult to compact material that is any less in thickness.
After all, as i said earlier, typical scenario, is that i'm given 100mm from concrete slab to top of finish material, and i've got my 20mm conduit to cover, which is secured to the concrete slab.
