Discuss Durabase CI or WP in the UK Tiling Forum area at TilersForums.com.
SirLurch
after reading many Q & A's i havnt been able to find this - apologize if i missed it.
My wetroom floor has new 18mm birch ply floor which is very solid and 10mm Marmox tile backers and planning tiling over with 500x350 ceramic
Q1 should i need durabase CI or can i just use durabase WP for the floor?
Q2 should i tank before or after UFEH ?
Q3 is the durabase tape just the same as the WP material for all joins and edges etc? obviously pre-formed for the corners is recomended.
wetdec
Hi
Bit of a waste the Marmox really as heat loss is minimal on ply I believe its 1% more than marmox.
Depending on the room size and flooring materials. With a floor 6-8m which is properly plyed and screwed at 300 cenres then Dura-WP will provide tanking and uncopling properties.
If the floor is to be bigger or with a suspect surface then Dura-CI should be used for tanking and uncoupling.
The primary difference of course is the height increase with Dura-WP is minimal.
You would tank before fixing UFH
The floor tanking kit for CI uses the same flexible core tape as is used in wall corners and material transitions in the wall tanking kit
:thumbsup:
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Just bumping this thread. If it's not a current topic then don't worry about it for now. Other threads like this can be found in the main tiling forum. If you do want to reply to it, please do. Your information may add value to somebody reading the forum in the future.
Reply to Durabase CI or WP in the UK Tiling Forum area at TilersForums.com
  • Sticky
Hi All, I'm about to start my first tiling job (at home) and after thinking about steps have a...
24K
Hi again Last week several of you helped me out with advice for a wetroom floor. There were a...
6K
Dumbo
Hi I am after some advice on the following, I have been to look at a job which had problems in...
8K
shick
Hi, New to the site, but been lurking for a while and I'm after a bit of advice about timber...
16K
J Sid
Durabase CI or WP
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
