Discuss edge of floor belt and braces treatment in the UK Tiling Forum area at TilersForums.com.
mellie_man
Hi
I have slowly been completing my wetroom refurb. and just about finished. Floor laid (but not grouted) and all but bottom row of walls. Before finishing I want a full belt and braces to prevent leaks. Shower marmoxed and joints tanked with Mira products. Was also going to silicon the gap between floor tiles and wall before tiling bottom row of walls and siliconing again. If this a good idea or a waste of time.
Thanks for all your help so far. Just very cautious with all the horror stories on here about tanking/tile/grout failure.:yikes:
Richard Edwards
I always apply an internal silicone joint if I can, then after tiling and grouting, apply a thin bead around all the wall to floor joints.
Tip -- when applying these joints, especially the outer / external one, check the seal quality by looking at the joint from the floor level - ie when lying on the floor with your head on the floor. Reason, if you have any small pin holes or gaps in the silicone, you will not be able to see them when standing up or even kneeling down next to the wall.
Belt and Braces - its what we do all the time
Reply to edge of floor belt and braces treatment in the UK Tiling Forum area at TilersForums.com
Hi any advice on what would go with what. I've layed off white tiles on floor with grey...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
The saga of my hollow floor 50sqm continues. All tiles now lifted but there is adhesive around...
TF Group Please Join
Tilers Forums on FB
