Discuss Efflorescence in the British & UK Tiling Forum area at TilersForums.com.
Hi, I had a problem with efflorescence in a BAL superlex wide joint grout back in December 2008. The whole 54m floor area was affected in a new build. It was cold and I'm pretty confident (it was a long while ago) that I would've explained my concerns to the customer at the time but he wanted to be moved in for xmas.
Within a few days it was apparent there was a problem. I suggested that the grout would need to be raked out and re-grouted (at my cost) The customer didn't like this idea because of the mess involved and delay this would cause for his moving date. In the end we settled on scrubbing the floor so I went back and scrubbed the entire floor with a "residue remover" which removed the salts and seemed to resolve the problem.
However last week I got a call out of the blue to tell me that there was still a problem and that "grout dust" is still coming up to the extent that it is being transferred into his carpets.
I'm due to visit him this afternoon and I wondered on fellow tilers thoughts as to whether or not this should be chargeable or should I swallow the time/costs?
brian c
what colour of grout is it?Did you use a washboy?DID YOU USE DUST SHEETS AS I CANT SEE WHY ITS GETTING ON HIS CARPETS IF YOU FOLLOWED INSTRUCTIONS.I would go and see exactly what the problem is and take some pics,then post on here and im sure you will get help.:thumbsup:
Did you overwipe the floor getting grout joints really wet when cleaning up excess grout?
DHTiling
Effloresence is just salt migration from the substrate or adhesive bed.... i can't see it causing the grout to break down and come out of the joints..
Now you say it was cold..?
This could have affected the way the grout dried and it might simply be a hydration/setting issue and the grout is knackered..
How cold was it..?
I'm not completely sure how cold, wooly hat weather I'm sure though :thumbsup:
The original problem was that the grey grout had a pale blueish layer. This could be scraped off to reveal the grey beneath. A Topps fella came out when I asked their advice. I had been using BAL for years and had never seen anything like this before, he hadn't seen it before either but the tech people said it was probably efflorescence.
What causes hydration problems? Is there any alternative to removing/regrouting
DHTiling
What happens is when you are washing off .. excessive wetting can cause the polymers to settle on the grout surface and leave this blueish tinge.... even a door left open whilst washing off can cause shading of the grout ..
You say you removed salts... were these white deposits in every joint ot just patchy.. they can normally just be brushed off and will eventually cease to a certain degree.
But this does not mean that this is the reason for the grout breaking up... Is there any UFH..?
Did you mix to correct ratio.. all this will be asked if you ring tech..
Its sounding more like polymers then because the deposits had to be scrubbed hard with a residue remover.
No UFH
As for ratios.... again I'm confident I mixed correctly.
My standard working method across a floor of this size would be to divide it into two areas,apply the grout, then using a washboy clean through half the 1st section before applying the grout to the second section and continuing with the washboy across the remaining floor.
Never had a problem with anything like it before or since, but switched to Mapei soon after this job
Ask as many questions as you want Dave :thumbsup:
I've been scratching my head on this one too. I've tried to go back deep into the memory banks and remember if there was anything out of the ordinary with this job. At the time it was just a normal job. I'd been on the job for a while, completed bathrooms, splashbacks, various other floors etc etc.
This was the main kitchen/dining room/utility area. Nothing unusual apart from this tinge. I do remember I was working late so it was grouted before the other trades came back because of the size of the area that I had closed off for a few days. I may have got on the grout a little too early but I couldn't be sure. I certainly wouldn't usually because IMO that makes the whole finishing process more difficult.
I'm at a loss with it. If it was something I've done, I'd rather know so it doesn't happen again though.
I'm just thinking what can be done to rectify the problem so that the customer is satisfied.
DHTiling
Sean.. if it was a hydration probem then it would affect the hardness of the grout.. this is if you grouted below 5dgs cels...
I would go look at the job first and if the grout is coming out then call a BAL pst out..
I am not sure who is the pst for your area as the present one has moved jobs i am led to believe.. but they will send someone out.
It is worth doing as it could be a bad grout batch.... and then take it from there...But i deffo would say it isn't effloresence..
This is currently the only pic I have available.... the wooly hat was ALL I was wearing :oops:
Reply to Efflorescence in the British & UK Tiling Forum area at TilersForums.com
Hi there, I’m not an experienced tradesperson by any means, so wanted to pose a question on...
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
Hi, I have had both polished and matt textured wood effect tiles laid in my house and am having...
7K
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
Essex
Efflorescence
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
