En suite wet room install
tbh ,contact wetdec on here and he will sort you out and give pro guidance on wetrooms as he is an expert in this field and he gives good discount to TF members.
also ,i think you will need some sort of screen to prevent the water from causing any damage in the bedroom etc.You can also slope the floor to prevent this.
I was hoping wetdec would have posted up but nothing as of yet lol.
Patiently awaits the info and help from you......
Hi
Ok lets clear up a couple of things.
The area the former is going is the stud wall end .........yes
How wide is the stud wall
How far from the stud wall do youu want to come out (wet area)
Which way are your joists running when looking at stud wall
You want to use ufh over the whole room
:thumbsup:
The man arrives. Im at work at the moment but i did a diagram and photo'd it see last pic with dimensions on but yes the former is going where the stud wall is, the joists run from door wall to outside gable end where the drain will go to. I was going to put the former from stud wall to door basically approx 1100 x 800 as big as i can. Yes ufh on the whole floor including shower floor. The diagram is nearly to scale for a pretty good idea of the room.
Thats ok always better from the horses mouth :smilewinkgrin:
I'l take a look later fr you m8 :thumbsup:
Brilliant mate much appreciated, i just want whats best for my situation as all these "kits" dont seem to fit my needs, without costing the earth, should also mention the floor to ceiling is 2.2m.
Looking at the Tuff2 grp base i see its 22mm thick and can span joists without underboarding, does this include the waste trap and so can it be installed easily as the other one, the type that dont need cementing in?
Also how would i then do the rest of the floor, i have chipboard down but it says i need to ply over with 12mm i think on wooden substrate, this would then give me an uneven floor?
I am ready to order stuff as well i just need to know which stuff to get.:lol:
Well from looking into stuff i need to remove the whole floor, add in the tuff2 grp tray span the joists. 5m floor dura ci kit and 10m wall kit, is the offer still on for the 5m wall kit. Then also ply the rest of the floor with 22mm. Whats the best price you can do for me please and does it include a drain waste trap.
Wow I didn't realise it had been so long since I started this project.
Unfortunately I had to put it on the back burner due to financial issues, nearly been made redundant in the process but all has been sorted and I can continue once again.
The room is exactly the same as per pics on page 1 except there is no floor at all.
Decided on everything and I shall keep this updated to show the finished article, as I'm sure lots of advice gets given out but not too many people post up the finished room.
I'm going to order the wetdec kit consisting of
Tuff2 tray former
Dura wp
UFH
Egg pod style toilet and basin
Thermostatic shower mixer with fixed head
Build in shelving/false wall style
Fully tile in travertine
Obligratory towel radiators
Ceiling spot lights
So a few more questions arise.
Firstly apologies for not ordering previously wetdec and I forgot how much tanking I need, how high to go and is the wp ok for the floor and does it also need to cover the former or is that already built onto the former?
With travertine is this a good choice for a wetroom, I see it needs maintenance regarding sealing?
Wetdec could you please give me a price for the former and tanking again please with and without the UFH.
Much appreciated.
junkie,
Dan,
junkie,
Dan,
