EV Pod cable (not charging cable) running close to hot tub. Discussion ThreadEV Pod cable (not charging cable) running close to hot tub. Electrical Advice
Hi;
In order to install an EV Charging point at the rear of our Garden for the Odd Designated parking bays we have, the reinforced cable for such would have to run the length of the Garden - where there is a hot tub Present.
Do these cables need to be x metres away from Hot Tubs? I'm getting Herbie Geebies about it visibly running immediately next to it - or is that ok? If it has to run close, is burying it an option?
(FWIW, the Hot Tub is a 13amp type, and we don't even plan on running it the overnights we'll be charging the car - this is a question about cable runs, but I suppose knowing any limitations we have might be handy).
Thanks!
EV Pod cable (not charging cable) running close to hot tub. for the original thread on Electricians Forums
Hi;
Thanks!
