Guest viewing limit reached
existing light (four wires) into new Led light Electrical Advice
existing light (four wires) into new Led light Discussion Threadexisting light (four wires) into new Led light Electrical Advice
Hi
I've got three lights in my hallway that I'm changing to a LED light fitting - they are all controlled by two separate switches. I've done two, but I'm stuck on the third one. The first light had one of each earth, L & N, and the second light had two of each (which I've squeezed in the connector block) but as you can see the last one, there's a lot more going on! is it a fairly easy job or do I need to call someone in for it?
[ElectriciansForums.net] existing light (four wires) into new Led light
Cheers!
existing light (four wires) into new Led light for the original thread on Electricians Forums
Electrical Advice
Lou,
Lou,
