Hi,I need some advice on a exterior patio I have been asked to tile.I have been tiling for approx 3 & half years & have undertaken a lot of interior floors but not outside.The slab to tile on is approx 15 sq meters & is a rapid set fibre based screed which has been down for 4 months & the tiles are 900/450mm by 20mm thick porcelain.My thought process at the moment is to prime with bal primer & the adhesive to use would be bal flex fibre plus as is semi rapid & allows for up to 20mm depth.I would be using a 15mm round notched trowel & back buttering.My questions to you are would you see this as the correct methods & materials for external & would you use a anti fracture mat or is it not needed.I forgot to add that the screed is very flat & has the correct fall on it.Thank you for any help given,I have been lurking on this forum for a while now & it has been a fantastic help to me with the extensive knowledge given out.
