J Sid
And a answer for me please @Tile Fix Direct Marketing
Ditra drain 8 needs a fall for the water to move through , if you apply your logic to a wet room You would say the floor doesn't need tanking as the water will just run down the drain.No that's true, but if the slab has falls do you need drainage membrane?
Max tile and bed thickness for this product please
yes frost could be a problem in winter as bal flex bone is a non adhered membrain and breathable in my view most suited but will check with rep.I'm with harry , is nobody concerned about frost lift . Ditra drain 8 is my favoured approach
Just done a patio with adpeds but it is a 25 mm build up approx .
