Discuss External tiling with porcelain - norcros rock-tite? in the Canada Tile Advice area at TilersForums.com.
We are looking at laying 20mm porcelain tiles outside. I am a bit confused over the different laying methods. Our landscaper is suggesting using hard core, then a scalping base, then 4:1 mix sharp sand and cement mix. Would this be ok?
I was wondering if they need to be on a fully cured screed instead or if anyone has used or recommends using norcros rock tite mortar as an alternative as this seems to be designed to go directly onto hardcore?
13
133
UK
Before I start, just to let you know I work for norcros, I'm not on here to actively push our products, just offer the best advice I can.
A solid re-enforced concrete base is my preferred option, but you will have to wait 6 weeks before you can tile, you can use a suitable external tile adhesive to fix your tiles, and remember to tile to falls.
Compacted type 1 is another option, preferably 100 - 150mm in depth, you will then need to use your sand cement mix to lay your tiles and slurry bond the back of the tiles with an SBR cement slurry, the slurry must still be wet when the tile is bedded into the mortar to achieve a good bond and once again tile to a fall.
Our Rock - Tite system is designed for tilers and landscapers, its a 3 part system, a primer for the tiles, fibre re-enforced polymer modified mortar and brush in grout and is designed for use on compacted type 1, much the same as the above.
Dave
Subscribed
389,936
1,000,000
Co.Durham
Without stating prices , how does it compare Cost wise to the method of screed and slurry fix. ?
13
133
UK
Mixing up your own sand and cement is always going to be the cheaper option, our system is aimed at the tiler who doesn't want to mix his own sand cement hence why our mortar mixes and feels more like an adhesive. When used in conjunction with the primer achieves the same strength as a C2 adhesive. I would say the primer is comparable cost wise, a 15kg unit will cover approximately 21m, you get 3 x 5kg bags that you mix with water.
Dave
Subscribed
389,936
1,000,000
Co.Durham
so basically to use over a slab and not hardcore ?
13
133
UK
Dave
Subscribed
389,936
1,000,000
Co.Durham
Reply to External tiling with porcelain - norcros rock-tite? in the Canada Tile Advice area at TilersForums.com
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
What is best way to lay outside 20mm Porcelain patio, Would I compact soil, add hardcore and...
hats67 - Yesterday at 11:48 PM Add bookmark #1 Hello guys. I came upon and registered with...
Hello guys. I came upon and registered with this forum while doing some research on decoupling...
5K
RH5, Surrey
What member type are you?
  1. Homeowner
Business Name
n/a
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 2 1.2%
    Votes: 5 3.1%
