Faultyblunt wheel on Rubi TX-1200?
Hi All, hope you're all busy and well. Quick query: setting a floor with Porcelanosa 660 x 440 10mm thick and using the TX-1200 for cuts. Scoring fine, but tile is breaking off in a curve rather than along the line (almost an S shape). Happened to three tiles now, have scored deeper but no joy . Used for walls and fine (ceramic though) and no problems in the past. Can use angle grinder for now but just thought I'd ask if there's a specific wheel to fit this cutter that you would recommend before I splash out?
I'd try with the 8mm. That's the one Rubi recommend for porcelain. But if it is going off in a curve, it could be slightly overfired, in which case you would have little success with anything other than electric.
As a guide, the optimal wheels for Rubi cutters are:
6mm = glazed ceramic wall tiles
8mm = all glazed and unglazed porcelain and dust pressed clay quarry (victorian style)
10mm = glazed ceramic floor tiles
18mm = rustic unglazed clay (extruded quarry tiles)
Cheers Paul, much appreciated
I've got a DeWalt electric cutter which is a lovely beast but would have to be set up outside and running up and down stairs with porcelain floor tiles is getting harder by the year....🙁
Had this recently with some tensioned 800's, had 12 on site, needed 12 and it was the last 12 tiles in the country, put a new 8mm wheel in the Tx, cut a small strip off your waste edge, doesn't matter if that breaks off line but it will release some of the tension in the tile then go for your measured cut, it helped a lot I found..
Tilergal,
Italy,
Tilergal,
Italy,
