Finishing To The Ceiling?
Caulk usually, sometimes grout. Strictly speaking it's a movement joint and should be siliconed but I rarely do it that way cos the ceiling usually needs painting once I've finished.
I Silicon to the ceiling if I don't like the customer!
(and smear too!)
Harsh that! I worked on a site of 300+ houses when I was 17 or so. Painters were ar#ehol#s, kept painting all the walls in the bathroom knowing full well we were tiling the wet areas. After weeks of arguments I began to write co#k in primer on the living room walls. Completely invisible until they started to emulsion. Took about 12 houses but they soon got the idea.
I've always ground to the ceiling, I run a wet sponge along the plaster a few times to wet it up so the grount moisture doesn't suck in, can get a nice smooth finish then. Although it's bound to crack at some point
I found a dark grout will stain white emulsion paint, that's why caulking filler does the trick.
If it's painted then deco fill, if it's a plastic ceiling then it gets siliconed.
It needs to be classed as a movement join & shouldn't be grouted.
Unless the ceiling is perfectly flat, which of course they always are, what's a wavy grey grout line look like against a white ceiling?
I'm a caulker by the way!!
White caulk looks like this!
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
