Discuss Finishing without trim in the UK Tiling Forum area at TilersForums.com.
If needs be..mitres around windows etc can be rather stunning......but make sure you charge royally for this type of work! ....here's one of mine ....Gaz http://i202.photobucket.com/albums/aa17/gazwalmsley_photos/SCANNERPHOTOS086.jpgHi Lads
If you had an external corner to finish but the client did not want trim what would you do if the wall was not straight and you had to cut the tiles to get a level finish.
good bit of work there Jeff well done m8.Here in Australia they hardly use trim they mitre most of the time.
Jeff
This is the way it was done before trims....but its not always practical...edges get chipped...corners are sharp...give me trims any day now.......dave....
Reply to Finishing without trim in the UK Tiling Forum area at TilersForums.com
