Discuss fireplace tiling in the British & UK Tiling Forum area at TilersForums.com.
smokie899
598
i have done loads of these. were the work is concerned they can be a bit tricky but i find if you take surround of if there is one tile the wall part first then the base always starting in the center and always try to use full tiles even if it means making base bigger (sand & cement). if not possible start at center again working your way out will give you even cuts (same size)and always miter cut edegs and corners far better finish. oh and put a good price in cuz if you do a good job on it you can be sure you will do more a lot more and after the first they become a doddle. hmm there could be a gap in the market hear as i have never seen a tiler advertise this:8:
GazTech
thanks smokie.so to clear up,i start on wall(the bit were the fire sits) pull the fire out. Start in centre above fire. Do i use a baton? as there is gap where fire sits. Or do i start at bottom(not hearth) either side of fire.
You have to use your tile to mark it out..if you have cuts try to make them as big as possible and symmetrical.....Gaz
Reply to fireplace tiling in the British & UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
fireplace tiling
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
