Discuss First complain about my work. TOTALLY GUTTED! in the Canada Tile Advice area at TilersForums.com.
Lee T
38
dorset
To be honest the bond issue is subjective as a true brick bond (as in bricks not tiles) would set out as you have layed the tiles with the Hal brick actuall being a full brick running in behind the full brick coming off of the wall adjacent as you have done. Same as if it was an external corner the full Tile would have a half Tile lapping around to make it look like a brick rather than a Tile. Some designers let you know which way they prefer and others just let you choose but can’t see a massive issue there. But the Silicon joint looks massive and the lippage quite bad as a result. But seen a lot worse on here to be fair
Lee T
38
dorset
macten
1,158
Nottingham
I always go small cut after big (even if full), big, big and small, small above just looks wrong to me but it's all very subjective as previously said so I always ask customer what they'd prefer if full tile in a corner works.
Of course tiles with a clear pattern and flow changes things, so would set out so the off cuts could wrap. I would have also had full tile off tray and drilled the pipe holes where they land.(unless there's more to it than the photo shows and you couldn't for some reason)
Reply to First complain about my work. TOTALLY GUTTED! in the Canada Tile Advice area at TilersForums.com
I have had my ensuite and bathroom installed in April. The job had ongoing issues during the job...
I’m halfway through tiling a shower cubicle at home. First time doing any tiling. I’ve used...
Hello, first post, asking about career change and possible entry route into the industry. I know...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
