Discuss Fix-a-floor. For fixing tiles with voids. in the Tilers' Talk - All Other Countries area at TilersForums.com.
smokie899
598
Got to use this fix-a-floor stuff today. What a load of... rubbish, and that's being kind.
One loose tile 300 x 300 and the grout cracked a bit.
Drilled eight 4mm holes in 6mm grout lines. Cut the nozzle for a snug fit. Injected it in.
Only about 5% went in, while most just came out the same hole. What a f'ing mess.
Ended up lifting tile spent about a half an hour cleaning up then relayed with adhesive.
Stuff has the consistency of melted ice cream, gets everywhere.
If they changed the nozzle to something with rubber on it, or just make it all rubber, to get a tighter fit in the drill hole, so more goes in the hole rather than out of it. That may help a bit.
If you see the advert for it on youtube, its nothing like that. Obviously staged to make it look so easy to use.
Demonsteve
Actually it does work but it's not as easy as they say, the trick is to use a dental pick and feel inside the hole you drilled, you have to find a hallow spot using the dental pick or a wire for the material to go in, if there's no hallow spot it will come right back out, I've wasted several tubes figuring this out, usually the grout is still sealed to the floor so you have to angle the drill bit to go under the tile, once you find the hallow spot it will pump right in, sometimes you will have to drill several holes but it does work.
Demonsteve
Ha ha, I'm amazed that you actually tried something like that o_O
Dan
Admin
Staff member
5,099
1,323
Staffordshire, UK
Register to the forum mate and tell us about fix-a-floor some more.
Reply to Fix-a-floor. For fixing tiles with voids. in the Tilers' Talk - All Other Countries area at TilersForums.com
Hi there, Has anyone had any experience with this product and what was you opinion on it? I’m...
6K
I had some advice here a while back on laying Porcelain Tiles on Outside porch , I followed...
Hi, I have had a bathroom and en-suite reconfigured as well as all new floor and wall tiles. I...
Hello everyone, new to the forum, nice to meet you. A tiler recommended to bring this question...
smokie899
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
