jond500
Hi All,
What is the best way of fixing into Hardibacker (12mm) Do you use rawlplugs etc. or a hollow wall fixing? The Hardi is screwed to studwork and is now tiled.
All I need to fix is the rail for the shower, the water is fed from the digital controller in the loft through the rail and then a small wireless controller for the shower.
The shower screen is glass but that's not really an issue as I was able to fix an additional stud prior to fixing the Hardi to screw into.
Cheers,
Jon.
Cheers,
Jon.
