Discuss Fixing mosaic's (horizontally) in the Canada Tile Advice area at TilersForums.com.
Hi there, I've done a couple of job's recently where the customer has wanted a horizontal mosaic border. Although the customer's have been pleased with the result I'm not!
I'm a bit of a perfectionist and I'm looking for advice on fixing the mosaic (the 15 x 30mm type that come on a sheet approx 300mm sq).
Next time I've decided I'm gonna set the room out and get some ally angle straight edges, screw to the walls and fix the mosaic's 1st and leave them overnight or 24 hrs and tile up to them - is this best practice?
I'm sick of the odd wonky mosaic, dipping in or out, up or down!! :mad::(
F
Flintstone
I don’t like the dog tooth method, I usually tile the whole room and use off cuts of tile to create the gap for the boarder, then I use mosaic mesh To make the mosaic more manageable, i butter the back of the mosaic to the correct amount and put it in. Too much chance of them all wobbling with dog tooth, in my opinion
MTiler
Most people tend to install the field tiles first then install the mosaics in the gap left for them. Where the mosaics are thinner than the field tiles theres various ways of building up the height. People use strips of backer boards, scrap tiles, mosaic mesh etc. You can also make a jig and use adhesive etc. to get your height. Whichever way you use make sure theyre set solid before installing mosaics otherwise theyll move about.
Just cut a piece of plastic etc to make a small trowel to fit the border size and youre sorted.
Sharon
I
Italy
schluter
Reply to Fixing mosaic's (horizontally) in the Canada Tile Advice area at TilersForums.com
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
5K
Dear TilersForum Thank you so much for the outstanding advice and expert information over time...
Hi all, Please see pictures... I'm struggling with these film fronted glass mosaics. They're...
I am updating the downstairs toilet and have discovered the original 1920's floor tiles below...
7K
Qwerty
Q
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Fatfield
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
