Fixing On Top Of Ditra Matting
Must be mate, but I did say I'm not talking about sticking the ditra down I'm talking about the depth of adhesive on top of the Schluter.......oh well maybe he was still was waking up and assumed that's what I was asking ☺️
The depth of adhesive on top is governed by the limitations of the adhesive as long as the square recesses are filled using your 10mm trowel the adhesive would be compressed to approx 3mm... Perfect
Hi chaps
I know is an older topic now but I will be having tiles fitted soon over concrete and timber. The concrete is being levelled slightly then 20mm warm up insulation boards being placed over it and the timber part is 25mm wbp ply and us having warm up 10mm insulation boards fitted which will pretty much level up the two different substrates. I am then installing warm up ufh mats (3mm) and the tile 9.5-10mm it has just been suggested to me that I should be using the ditra 25 mat as well to help prevent any damage afterwards from the two different floors expanding and contracting. Is this a recommended way to go? Wouldn't want cracked tiles at the transition point one complete? Any advice please and if recommended does the warm up mat sit in top of the ditra or below?
Hi chaps
Hi. Warmup mats go below the Ditra, cover with slc first though. As for the bridge between the two floors, ditra will go a very long way to absorbing the lateral movement but it's more vertical movement which will present the biggest risk. That's why Schluter will say the same as i will: you should install a fixed movement joint, such as dilex, on the joint and follow that through the ditra and to the tiles. Can look ok if planned properly.
Thanks Impish
Not had any advice of my tiler in ref to the transition between the ply and the concrete. Told him I'm planning on using 20mm insulation boards on top of the levelled concrete and 10mm insulation boards on the ply but the 10mm boards would bridge and stagger across the different substrates adhered with tile adhesive and have asked him to lay these for me. Then warm up heat mats in the tile adhesive above then the tile. It was mainly my plasterer that has suggested I use the ditra 25 mat as well but ditra have said they would put slc over there mat? I only have 30mm over the ply and thus is to include the tile and insulation board. Very confused now and the work starts in a few days. Any advice from anyone greatly appreciated.
Thanks Jobdone but unfortunately already purchased 51sq mtrs of warmup mats. Got around 31mm on top of the ply but have 41mm over the concrete now it's been screeded.
MW Smith Ceramics,
Old Mod,
MW Smith Ceramics,
Old Mod,
