grayless
Hi
Has anyone used the Bal single part fast flex with hardibacker for floor tiles and if so do you need a primer? I can see it is recomended for use with Fibre reinforced cement boards and lightweight tile backer boards, but i'm not sure hardibacker is either of these. Also i cant find what coverage you get from the 12.5kg bag.
I have always used Bal flex ( two part )both under the hardibacker onto floor boards and then under the tiles, as the only time i used a cheaper alternative the tiles moved, i am hoping the Bal single part fast flex will work as it would be cheaper.
