Discuss Floating stone in the British & UK Tiling Forum area at TilersForums.com.
Spud
i fix i a similar way to this, the bloke in the video, has his float bed, as he calls it ,mixed too wet and there is no need for the adhesive , slurry mix is better ,he would need to be backing his tiles with rapid set as slow set doesnt work well when fixing like this , the only benefit when fixing like this is you can lay stones of differing thicknesses to a perfectly flat finish
here are some pictures of me laying a floor like this where the substrate was asolutely knackered up and down all over the place as i say i use a slightly differnt method that the old timer italians used to use
Perry
it would work but a bit crazy the adhesive on the floor and the tile with screed in between or else the screed wouldn't adhere but whats the point only if you have a in between thickness not deep enough to screed to deep for adhesive but would take a long time to lay and dry if you are laying on screed skim the tile or slab with adhesive it will never come up : Pete
Reply to Floating stone in the British & UK Tiling Forum area at TilersForums.com
Hi any info on get rid of epoxy grout haze on natural stone would be much appreciated. I’ve used...
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
  • Sticky
Hey guys, Thanks for being members here on TilersForums.com - it is a pleasure to have you! I...
Floating stone
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
