Diamond Pool Finishers
DON'T worry mate they are great to deal with !, i buy loads of my stuff from them !!
An old tiler once told me that a coin would be rolled across the floor, hopefully not hitting a lip otherwise it would jump.....
So is the wall kit 3mm base clips & floor kit 4mm base clips?
no mate the standard white plastic one's are 2mm spacing
i bought the dearer pliers ,they are much better quality,and you get replaceable plastic jaws ,not that i need them !! i think they are for dirty workers really the type that gets adhesive everywhere !!!lol.....
Sorry what I meant to say was reused. Or do the pliers squeeze and deform them too much?
[video=youtube;01eifzeMxhU]http://www.youtube.com/watch?v=01eifzeMxhU[/video]
i love the commentator on this one :smilewinkgrin:
It's quite a big out lay for something of probably use once. I enjoy the way I do it & I feel it's done right. Don't fancy having a runny mix. Just makes a poor, brittle adhesion to the substrate. Think ill stick with the old skool way 😉
Chatting to the USA lads on their forum bubbles , they are mixed results with them.. some say then use them all the time and others say you have to use wetter adhesive than normal to get tiles to pull into place.. now over wetting adhesive IMO is weakening cement to water ration and could impair tensile strength..
Any tiler worth his salt can tile a flat floor and with very minimal lippage.. the cost of adding a gimmick like this is stupid and some tilers really struggle as it is with costs...
my take on it is , some tilers use battens and some do not... the same with these.. if they work for you and you can retrieve the costings then go for it. 🙂
Will be interesting to see how Gary and co got on with them. Think they done/are doing a test with the various types of clips using glass to see what's actually happening underneath.
Wouldn't rule them out on very large format stuff although a decent tiler should be able to lay a good quality run of the mill floor without them. I find it contradictory the way you need to have a flat well prepped floor for them to work though.
