Burnz0
On the advice of the kind gentleman in the builders merchants I put down 9mm ply over the floorboards in my bathroom in prepartion for tiling. I've since learnt that 9mm is not thick enough and I should aim for 15mm minimum, ideally using backerboard instead. Having spent a bit on the ply already I'm wondering if there's any way of salvaging the situation? The options are - remove completely and redo in thicker ply or ply+backerboard, put another layer of ply on top - 6mm or 9mm, or some 6 or 9mm backerboard. I can't afford to lose too much height so the thinner the better and if possible my preference is to make use of what's been done so far rathing than starting again since these things take me ages and it'll feel like a wasted effort and money if I have to remove it all - and a load of unscrewing.
Can anyone advise the best course of action? If it makes any differnce - I did the water in the middle of the room test before the ply went down and it was fine so I'm quite confident the floors pretty sturdy. I may still pay someone to do the actual tiling so I don't want the subfloor being an excuse if things go wrong in the future
