Discuss Floor screed drying time - advice please in the UK Tiling Forum area at TilersForums.com.
grumpygrouter
Check out the installation guides on the Schluter site, I think, but don't quote me, that you use standard adhesive, not flexy, on both sides. I.E BAL rapidset or Ardex S16 or something similar from other manufacturers.
I also thing you can get the Ditra from Walls & Floors for about £6.5/mtr. (may have to buy a full roll though)
Grumpy
I have just checked - 5mtr roll £65 +vat
Grumpy
DHTiling
Ditra is spot on for this type of installation... here is the latest 2007 handbook for ditra installation.....
http://www.tilersforums.com/tiling-forum/5551-2007-schluter-ditra-installation-handbook.html
Also as mentioned you could use a green screed adhesive.....
BAL Green Screed Adhesive
A grey, highly flexible, water and frost-resistant tile adhesive suitable for fixing all types of ceramic floor tiles, including porcelain, ceramic mosaics, terrazzo, natural stone (excluding marble) in interior and exterior locations. It also provides enhanced adhesion to low porosity substrates. Suitable for situations where fast track installation is required, i.e. recently laid screeds or concrete. Suitable for use in showers and swimming pools.
mick7
Ditra - I'm ready to go.
What a fantastic forum - thanks all for the great advice.
I've just ordered the ditra, and will use the adhesive recomended to stick the ditra to the new screed.
I'm only an amatuer I'm afraid, not an expert like you guys and this will be my first time laying a porcelain tile floor. Its just under 4.5 metres square on new screed ( level I hope) . Clear room, only one small post to cut around.
I've watched the ditra video - pretty helpful for an amateur like me and I'm ready to go.
So I'll trowel on the adhesive to stick the ditra ( do you think I need their branded tape to tape the ditra joints or can anyone recommend a cheaper one?) to the new screed and then trowel on the adhesive to lay the porcelain tiles on. What adhesive ( flexible??) do you guys recommend here for 60 x 60 porcelain tiles?
I'll seal the tiles first with Lithofin impregnator before I lay and then again after I grout. Is there a problem with the adhesive which appears dark in colour staining the tiles?
Someone recommended a porcelain tile cutter for about £60 from Boydens in Croyden, that sounds pretty good?
If this little 5 sq metre project goes ok, I might try the slightly more daunting 45 sq metre.
Any more advice before I start more than welcome.
Reply to Floor screed drying time - advice please in the UK Tiling Forum area at TilersForums.com
L
Hi guys, I've just installed Weberfloor flex in a small area 1m2 @35-40mm depth in one pour...
leoder
L
Hi everyone I’m after a bit of advice. I’ve just removed the floor tiles in our on suite. After...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
