Discuss Floor screed drying time - advice please in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
There are many brands suitable for use on Ditra but if you want to use a BAL one then use bal goldstar.....
BAL Gold Star
A grey non-slip water/frost-resistant cemetitious adhesive for wall and floor applications with BAL Porcelbond Plus Technology allowing it to be used for fixing fully vitrified and porcelain tiles to a number of backgrounds/bases, such as concrete/brick/block walling, concrete bases, cement:sand rendering/screeds, plaster/plasterboard, mastic asphalt and backgrounds with a low porosity. Suitable for exterior and interior use. Extended workability time.
mick7
Great, does that mean I can use the Bal CTF3 that I've already bought from Topps, it seems that it comes under the same heading as Bal Gold Star ??
Sorry to cross over to my other thread, but do you recommend I only use a third of a 20kg bag of green screed adhesive to get thin set coverage for my 5sq mts floor?
Should I use a 6mm round notched trowel instead of my 13mm round notched one??
Many thanks agin for your help
DHTiling
This is a reply i got from schluter about adhesives for ditra.....
Dear Mr Howe
Thank you for your enquiry regarding the application of Schlüter®-DITRA.
Please refer to www.schluter.co.uk for recommendations in the UK.
The type of adhesive used to apply Schlüter®-DITRA depends on the type of substrate. The adhesive must bond to the substrate and mechanically anchor the fleece on the underside of the Schlüter®-DITRA matting. For timber substrates, a vinyl acrylic adhesive or hydraulic cementitious tile adhesive may be considered, e.g. Ardex AF200 or single part flexible.
Immediately after the Schlüter®-DITRA matting is installed, the tiles can be fixed using the thin bed method and using an adhesive that matches the requirements of the tile covering. Therefore, porcelain tiles will require the appropriate adhesive, which will bond to the tile.
We hope that this helps with your enquiry. If we can be of further assistance, please don't hesitate to contact us here at Bardon 22.
White Room
I've asked this question before, So then it means porcelain will need a modified adhesive on ditra :whatchutalkingabout
F
frogeye
Hi folks
now I am in this position - refurbished the back of my house - just a downstairs toilet and a utility for the washer and dryer.
I have laid a screed - about 80mm 3 days ago - I will need to level it then tile (screeding isnt easy!).
So when to seal (with what?), when ready for self leveling and when to tile? I have read
1 day per 1mm that's about 2 .5 months!!! surely not?
The hurdles I have jumped through thanks to building control - the old tiles were laid on mortar and dirt - lasted well for 50 years - but I had to dig down half a metre, use hardcore, sand, dpc, 120 mm polystyrene, concrete and then screed, Got over an inch for a teracotta tile. time line anyone? Need it done for Xmas. Prices? Oh and recommended mats would help - no ufh to be fitted
frogeye
The D
Hi folks
frogeye
have a look at this thread Cyril Potter, Chief Chemist at Ardex UK
F
frogeye
hi deano - i searched for the link to cyril potter and read the info - to wait a whole month was depressing reading - i like the idea of penno - lay on sand and cement as of now.
So floor prep - seal with what? self level for a measley 9m2 ( I am a crap screeder) but when to lay tiles? Looking for a time line here as I still have to fit the loo, make the room, fit the plasterboard, skim, do the ceiling.............. god it was only a quick refit - £ 4200 so far
Reply to Floor screed drying time - advice please in the British & UK Tiling Forum area at TilersForums.com
L
Hi guys, I've just installed Weberfloor flex in a small area 1m2 @35-40mm depth in one pour...
leoder
L
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
