slartibartfast
Hi
I'm sure these questions have been asked before but I can't seem to put the info together to understand what I need for my situation, so any advice would be gratefully received.
I'm planning to tile my bathroom using floor tiles on the walls as well as the floor. I am using 33CM x 33CM x 8mm ceramic floor tiles purchased from wickes. The wall area is approx 9m[SUP]2[/SUP]. Some of the walls are made from a strange type of plaster blocks (but are basically plaster) and partly painted, the other walls will be fresh plaster. I have cleaned off all the old tile adhesive and now have a pretty flat and stable surface to tile onto. What tile adhesive should I be using?
Secondly, the floor is freshly laid 18mm moisture resistant chip board over 50x170mm joists spaced at 410mm. The floor area is approx 2.5m[SUP]2[/SUP]. Do I need to lay plywood over the top or can I seal the chipboard and tile directly onto it? And what tile adhesive should I use?
I'm on a tight budget so I'd prefer to use a "best of the rest" adhesive and grout rather than shell out top whack for the very best.
Thanks in advance for any advice.
