Guest viewing is limited
Discuss Floor tiling - 18mm ply in the UK Tiling Forum area at TilersForums.com.
GaryVenters
Yep, that's the way to do it, use WBP ply and use an SBR primer on the UNDERSIDE and edges, if there's any movement in the floor at the moment then brace the joists, then get a good flexible adhesive suitable for ply, cement based ( bags ) not tubbed gear :thumbsup:
You say use an SBR primer on the UNDERSIDE and edges, do you have to prime the Topside aswell of the ply ?
Reply to Floor tiling - 18mm ply in the UK Tiling Forum area at TilersForums.com
