Floor Tiling advice and are additives necessary?
If it's Quartz from Topps, the manufacturer recommend a "low water content" adhesive. Not "zero water content". So you can use two part or the mix of products Topps suggested.
So if the adhesive was the Bal Pourable One, the combination will be 1 bag, litre of AD1 additive, to 3 litres of water (instead of the 4 litres used for normal ceramic and porcelain tiling)
Well heres the pics, I'm happy with the results though I would concede it was more difficult than anticipated and there was certainly a learning curve with the levelling and even just the work load for one person.
Don't get me wrong I'm very pleased I did it and I will be doing the utility room/Toilet next but it's easy to overlook lifting tiles and grout bags into place, dry laying them all, the mixing and dropping tiles into place, certainly the 600mm, all of that when working alone is tiring. The cutting which I thought could be tough on quartz was actually very easy.
I didn't get started due to the kids until the Sunday (11th March 13:30ish) afternoon and went into the early hours, I called it a night at 2 thirds done and finished in the morn, grouted afternoon.
Very pleased but at the halfway mark around 10pm at night I had a few doubts, I was pretty tired but the result is great and I feel I accomplished something and learned a lot which is what it was about for me. Thanks for all of your help and warnings 😉 You were indeed correct and I would advise anyone to carefully consider the sheer workload of an area larger than 5 or 6M2.
For what its worth the Mapei Granirapid with supplied Mix was great, I ran out and had to get one bag of the Topps supplied Bal fibre plus with some admix which stated 15 mins longer work time but I'd say the Granirapid was longer lasting and a little easier to work with for Quartz.
Anyway heres some pics
Would it be ok to run the wire along (in last pic), part under a 2 tile grout line (along doorway) for under cabinet and plinth lights and to grout over? Thats my plan anyway so I have one small part still to grout as well as Skirtings and door frames to fix.
20180321_001216.jpg 20180321_001518.jpg 20180321_002645.jpg 20180321_153519.jpg 20180321_001319.jpg 20180321_001344.jpg 20180321_001358.jpg 20180321_170933.jpg
Thanks for your photos. Sounds like you have been hard at work. What did you cut the tiles with (i've never used that material before)?
Hope the family like your hard work.
Thanks Julian, The GF is very happy so I am safe for now 😉
The pics don't really do the tiles justice as it's movement that makes them sparkle.
I used a pretty basic wet tile cutter (Plasplugs Compact XL, £40 B&Q) and I brought a 110mm Vitrex cutting Disc I think from Amazon, really surprised me how easy the cutting was. Prob didn't even need the new blade.
Some other things that could possibly help DIY'ers.
The White china pencils where a god send too, I marked a few areas of the floor as I dry laid and after laying the first 2 tiles I realised I was slightly off (about 1mm but would have become more by end of run?) due to these lines, I quickly realised that every cut I had made would be off without correcting that. I had marked the first row clearly but I think it was due to the fact that once the adhesive is down you cannot see the lines so next time I'll probably fix a starting batten?
The floor was very flat except for one slight bulge, I read to start from the highest point if there is slight imperfection.
That would be my number one thing, get your first couple of tiles down very accurately as there's big potential to go wrong even if just slightly offline!
The other thing I brought off an online check list was the paddle mixer drill attachment, I'd not have thought otherwise as I previously mixed by hand but the floor took a lot of adhesive compared to the walls! I would not have wanted to mix that quantity by hand, it was hard work even with a pretty decent drill, in fact that was smoking a little at one point!
I really did learn that there is quite a lot of heavy work on your back and arms which is the main reason next time I do more than 6M2 I'd be giving myself ample time. I back buttered or spread (whatever the correct term is for a thin spread of adhesive) every tile and they were certainly much much harder to pull up once I'd done so so that's the other thing I learnt from my You Tube Videos, simply dropping large format tiles on top of adhesive and giving them a wiggle will give much less adhesion (Something I came across numerous times during my research)
I had around 10.8M2 of tiles according to Topps for a 9.7M2 job and finished with one full 600mm tile spare and that was due to the planning I put in, I figure there's more potential for loss with larger tiles. It would have been another £120 odd for another pack of 3, though I guess they sell individual tiles and take them back too?
I hope my experience can help others but like I said some of the warnings here are well worthy, next time I might just accept a little help and certainly with the initial set up (dry laying etc)
My 3 Year Old boy is some way off unfortunately but he is a key reason why I want to learn, to be able to teach him some basics at least 🙂
Try again...
For any DIY enthusiast reading this there's a few points I would like to make.
I wouldn't bother with a £40 plasplug cutter from B&Q......a grinder with a decent blade will be 10 times quicker and easier to use..
Use a metal straight edge or laser to keep your tiles in line, never try to free hand them down, you need a straight line to tile off..
Use a Proper paddle mixer to mix the adhesive, a drill is to fast and will burn out or you will end up with adhesive everywhere..
Any high points should be ground level or the whole floor should be leveled using SLC to prevent voids under the tiles.
And finally, be careful what you see on YouTube, alot of the advice on there is completely wrong, and posted by builders that haven't got a clue about tiling..
You have done a good job for DIY and if your partner is happy aswell then it’s a winner. Well done !
£120 for 1.08m.....jeeesh Topps are outrageous.
I agree they are expensive but all samples we ordered and the next door tile Giants same range were no way near as impressive, I have to say that every single tile looked amazing.
I think Tile Giants range was around £75 M2 with tops around £85 M2 but the difference not just with the mirror particles but the actual Deep black Quartz looked like at least 25% better and they look much more black, the Tile Giant looked a little Gray. We also ordered samples from 2 online places and they were just over half the price but no way near as nice,
I tried researching popular suppliers but didn't come up with much so I just thought If it's gonna be done it needs doing with the best I could find, I honestly think it would have been a bit underwhelming with the half price stuff. This was a big outlay to us but if it lasts us the 5 years or so were here and someone else 10 to 15 years or more then I'd say for the effect it gives it's worth every penny and will certainly add value when we sell our house.
Thank you, that means a lot.
I was looking last night at some of the photos in the galleries on here and have to say that most of the work is immaculate. Some of those intricate designs I wouldn't even think of attempting.
Try again...
All due respect but I cannot agree with some of this.
The Plasplugs cutter worked seemlessly on these type of tiles, it was extremely easy and as for cutting by free hand, take a look at the line along door step (thats an angled edge) and the one along the cupboard threshold, it wasn't a problem for me but then I'd say people know if they have the eye and patience for that.
As for the drill, maybe you are right but my drill has 2 gears and the first was certainly not too fast, once the mix was almost there I turned up the speed which is when the drill struggled a little so low speed is the way to go, had it not been for the 2 gears I may have struggled to get control, I know this as I started in second gear 😉
As for the high point, to me as a DIY'er it made sense to start there after taking advice on that may I add and it worked for me. I'd have been very reluctant to use self leveling when the one bad point on the whole floor was minimal, before I pulled the old Vinyl tiles up I was dreading what I might find but it was a dream, It wasn't until I got down on my hands and knees with a level that I realised there was one small bulge.
Thats a fair point though and you know far better than I but I would agree that making sure that floor is as level as possible is vital and as for a laser, thats a great bit of advice, I will be using that next time. The white lines did help but covering them with adhesive was an issue!
Again as for YouTube, if you look at at least 3 or 4 videos specific to what you are unsure of you will highly likely find the right or an accepted answer. Mine was to do with back buttering and adhesive depth mainly, I didn't come across much of a variance, in fact I came across many videos explaining the difference in grip by applying adhesive to the back of the tile before laying. That gave me confidence, certainly after testing the strength that would ensure a longer lasting floor. Simply the back buttered tiles needed leverage such as a crow bar to get back up immediately after laying whereas unbuttered they could simply be lifted. Without you tube I wouldn't have realised that. So whilst I'm sure there are a few bad videos out there I would say that if you do enough research you can't go far wrong.
I've done a lot of DIY with the help of the net and have yet to get advice which I later find out to be bad.
Granty,
T14086,
Granty,
T14086,
