Discuss Full floor prep in the British & UK Tiling Forum area at TilersForums.com.
K
kaharrison9
Evening all
Wondering for your thoughts on the best way to prep a 50sm2 that i may have coming up.
It's an exstension and the floor will be running through the new and old part of the house.The old floor is to be taken up back to the joists
There is going to be a wet ufh system and the buider has suggested chipboarding(18mm) the whole area,laying the ufh on top then 6mm ply screwed over,then tiled.
I suggest hardiebacker 12mm on the joists,then ufh,uncoupling membrane then tile would that be fine or have i missed something obvious?
Possible questions could the 18mm ply replace the cement board?
If fine could ditra go straight over the ufh heating channels filled with adhesive or would a slc be best
Cheers for your thoughts
Kev
Gazzer
Evening all
Kev
Is this an error ? Are you specifying 12mm Hardibacker straight onto the joists ?????
K
kaharrison9
Not an error,it's what i'm asking before i contact the customer.
Can 12mm cement board go straight onto joists as i would have thought it was more than equal in strength to a similar thickness ply and a more stable background with the heating if possible.
If i'm way off the mark here could you please tell me how you would spec the prepping
Cheers
K
kaharrison9
That's good to find out the cement board hasn't the strength.
Would 18mm ply be enough or needs to be thicker?
As i mentioned to Whitebeam at the moment dont have to much info on the system(talked over the phone) though it does have 18mm boards with grooves for the pipes.
I was thinking of going straight over with an uncoupling membrane,would you?
Gazzer
The only way you will know if the floor is strong enough is to try it. If the joists are visiable then why not add extra noggins or even laminate teh sides of the joists with 18mm ply to add strength.
Without knowing the actual scale of the floor its hard to tell. 50m2 could be 25m long and 2m wide ?
If its the polypipe type system the boards need too be fixed to the substrate and then I have in the past used SLC over then Dural Ci then tile.
K
kaharrison9
I am see the customer soon so will have a clearer picture.
Can i ask why do you self level. Is this to bridge over the pipes or for a better surface to tile on?
Could the Dural not go direct onto the substrate using a quality adhesive like Keraquick and at the same time filling the channels with adhesive
Thanks again
Rob Z
Hi Kev
It's good to remember "the 4 S's" when deciding what to do on the floor (for you former military men this is not the same as the 3 S's:smilewinkgrin: ).
The four S's:
Size: of the joists
Span: unsupported span of the joists
Spacing: the on-center spacing of the joists
Species: the type of wood
If you are able to determine the above information, it goes a long way towards helping to decide what the best approach is to prep the substrate. There are various "deflectometers" on the web that help to calculate if a floor is suitable for tile or not. I can point you in the right direction if you're interested.
K
kaharrison9
Actually seeing the customer later this week and the method i propose on top of the bare joists.
Extra noggins where seems needed
18mm wpb ply screwed down on top
The wet system panels then placed down and also screwed down onto the ply and joists
A latex based slc poured over the panels(2-3mm depth) and the pipe channels
Then finally dural ci matting.
Would that sequence appear to give us the best chance for a long tem instalation.
Cheers again
Reply to Full floor prep in the British & UK Tiling Forum area at TilersForums.com
Full floor prep
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
