Discuss genesis tiger trowel in the Canada Tile Advice area at TilersForums.com.
If you want a good trowel that makes achieving a full bed relatively simple, get a ragni 10mm trowel.ill not bother then.... hardly a flying colours recommendation
With banana handle I do believeIf you want a good trowel that makes achieving a full bed relatively simple, get a ragni 10mm trowel.
It gives 10mm deep serrations which are very thin and close together. The ribs are easy to collapse, which makes fully bedding tiles much easier than with a regular 10mm notch trowel.
Available from Amazon, selco, some B&Q's and I believe Travis Perkins.
Reply to genesis tiger trowel in the Canada Tile Advice area at TilersForums.com
