Discuss Getting wet from the wet cutter. in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
I'll have to test this pulling towards you business...i'm not sure about line of sight...i'd prob have to take the guard off...and for complicated cuts?
NB! I already wear a scuba mask! got a bolle one find it ideal for tiling...bits can't sneak in and it doesn't steam up...eash just to lift on head also.
lacky? what is this?
No simple really, takes up quite a bit of room though.bit pricey? looks a bit complicated also.
im using my angle grinder with a marcrist blade when ever possible these days instead of the wetcutter , ok you have to go outside but i usually set up the mixer in the cliients garage and do all the cutting and drilling there too, gives you more space to work inside...
Reply to Getting wet from the wet cutter. in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
