MTiler
P10 is good, but I always have to order it.
And I thought this was the proper place to get advice!!!!!!!
Just as well I know you all.
Anyway, they are clear cellophane tacky front fixed sheets, but the adhesive will 'taint' the final visual look of the tile - so I'am after the whitest, the colour of the grout will be my next thread!
Today I skimmed the walls over with a white (ish) adhesive so no background colour would bleed through, and with all this invaluable information I am now in a better position to make my final choice.
If I use 'white tack' would I have to put a piece on each sheet or each tile (11,250) and as each tile is 20x20mm what size blob (if that is the technical description) would you suggest.
Thanks for all your 'help' and if it's successful I'll try and post some pictures.
Have you thought about using flour and water? I use it to fix all my tiles and it can also be used as grout :smilewinkgrin:
Nah, the salt will cost to much. Iv been using flour and water for 173 years and Iv never had a problem :lol:
Does anyone know if you can get a translucent grout as I don't think I will get away with clear Silicon on 11,000+ pieces of mosaic.
Update - all tiled and thanks for all your advice - it's certainly the place to come for all the friendly help that I've received. I won't hesitate to ask again when I start my next project - the Tyne Tunnel.
As I went to a trade show this morning I picked up a 20kg bag of Mosaic Fix - and I have to admit a lovely white adhesive which mixed to a thick smooth consistency and lasted well in the bucket for use.
Now when I go back tomorrow, to do a floor in a 450x450 porcelain, I'll check to see if they are still on the wall.
I have no doubt they will be but that is before I try to take the cellophane off the fronts, it seems very well adhered.
I shall be doing a couple of test swatches for the grout as I don't want to loose the depth of the tile that is visible at present. Does anyone know if you can get a translucent grout as I don't think I will get away with clear Silicon on 11,000+ pieces of mosaic.
It may have to be white or a very light grey.
Thanks again - great place this:smilewinkgrin:
