glitter grout
kilty55
hi all,i have a job next week and am trying to talk the customer into using glitter grout on her glass mosaics,never used it as off yet is there a big price diffference in normal mapei grouts compared to the glitter? also any tips peeps on using it would be appreciated:thumbsup: many tas
Jamie,its expensive m8....glitter comes in a packet and you mix it into the grout...ctd sell it dont know if TG do.:thumbsup:
Designer epoxy not the standard epoxy, used it at mapei but have heard it's expensive.
Easier than most to use though
tile giant do stock it now!
it's a pain in the *** to get of your gear,bill the customer for new float and sponges and bucket! just make sure you mix it in properley so you don't get spakly and dull patches!:thumbsup:
its around £40ish for a 3kg tub of Kerrapoxy design and then another £10 for the glitter. You can get bigger tubs 5kg and 10kg but I dnot know the prices of them.
Constantly try to clean as you go, cleaning tiles and your tools on every opportunity.
Pricey stuff so get accurate idea of quantity required. The grout density factor for this product is 1.5 so the fllowing formula should be used to calculate grout quantity
tile width + tile lenght = A X grout widh X tile depth X 1.5
NOW DIVIDE THIS BY
tile width X tile height
for example lets say that your mosaics sheets are the following spec,
25x25mm tile
2mm spaces between each tile
8mm tile depth
your formula would be as follows;
25(tile width)+25(tile length) = 50 x 2(grout width) x 8 (tile depth) x 1.5(grout density factor) = 1,200
25x25 = 625
1,200 divided by 625 = 1.92 kg per msq
so you would need 1.92kg of kerapoxy design for every msq of mosaic at the above spec
hope this helps and appoligies if you already know this formula.:lol:
Prices are as per tfs :thumbsup:. I usually get it from TG but some stores will quote a minimum of 10 bags of glitter (seems that silver is popular but gold is as rare as rocking horse poo).
I keep a float, bucket and sponges separate for glitter as it will stain your gear.
When washing off, use warm water and work a small area at a time (1 sqm average).
It looks the dogs danglies when done Jamie.
Good luck,
Daz
** Also, only mix a max of 3 bags glitter per 3 KG poxy. Personally, I think 2 bags of glitter is plenty.
done right it looks fantastic with the right tile
i belive two packs of glitter to one small tub of grout i think is the best mix
and yes make sure you work clean and allow for a wasted sponge bucket float etc and also dont forget to explain to your missus why you are late home covered in glitter
tell her before or she will think you have been lap dancin
How many times will you get away with that excuse Chris ? :lol:
glitter grout
kilty55,
Diamond Pool Finishers,
kilty55,
