Discuss glue gun in the UK Tiling Forum area at TilersForums.com.
kilty55
1,113
edinburgh
wish i had bought this a long time ago,i have asked before which one was best for sticking ufh down with and ended up buying a cheap 14 pound gun from b and spew,sticks were a fiver for 4 i think also and only used 2 to lay a small mat
what a difference rather than faffing about with tapes etc,used it on a loose wire system and made it so easy and flat to work with
big recommendation from me for the cheapo loctite glue gun:thumbsup::thumbsup:
jolly fix
i tend to use both tape and glue gun,i find tape quicker,as with a glue gun you have to make sure you hold the wire in place for those 5-7sec's for it to go off enough to hold.so i tend to tape some points of wire (bends),to get the wire in position fast,then use glue gun ( to hold wire down on the rest of bends,and run) .i have found this much quicker for me than just using tape,or just using glue gun.
Reply to glue gun in the UK Tiling Forum area at TilersForums.com
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
So, I'm doing my own floor, and for the first time I'm putting wire underfloor heating over...
5K
White Room
hi all,does anyone use a glue gun for sticking down ufh wires? if so what make model...any help...
8K
Time's Ran Out
Hi all, first time poster here. last week I laid loose wire UFH on top of cement insulation...
Jimwilts
I picked up a tip from here ages ago about using a glue gun to keep the mats down when levelling...
8K
Tilers Forums on FB
