Discuss God bless the levelling sysyem in the Canada Tile Advice area at TilersForums.com.
F
Flintstone
Do you use the pliers Andy..
And do you only use slow set...?
I normally just use rapid on floors.
I used to use the pliers but I use them less and less now. I only use the pliers if I'm having a bad time and need to really clamp them up. If your floor is good and your trowelling is consistent then you can just use your hand. I only ever use slow set unless I need to tile and grout in one day which is rare.
Sean Kelly
1,068
Ruislip
Tip. If you are going to buy 1000 1.5mm shmox clips off eBay then don't!
1000 clips is £48.95 but
1200 clips is £47.99!!
Also, the shmox pliers bend. I use my hands to push the wedges in.
Reply to God bless the levelling sysyem in the Canada Tile Advice area at TilersForums.com
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
This is the Number 1 Best Tile Adhesive from 2007 to 2021 recorded (almost) annually Discussion...
Has anyone done any work like this? We are having a pvc door removed between dining and utility...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
