Granfix Grey Grout Dried Different Colours
Grout lines look like they've been washed off way too much. Tiles are stepping quite a bit.
Not the best tiling that.
I thought you were DIY when you first asked but you say this is a customers job. :-/
You need a tool like a Fein Multimaster with a grout removal head on it. (Available from www.TradeTiler.com) or a grout rake (also from TT). But it'll take you ages with a rake. Then re-grout.
Thanks for comments, taken on board. Not too sure what funky and stepping means ? I am learning, still a way to go. Another question, is there a minimum bed thickness for floor tiles to stop height of floor being raised too much ?
It's more than likely moisture evaporation causing the dark patches , if you grout to early when using a dispersion adhesive , then staining can occur as the moisture leaches through the joints.
Ok thanks. I did leave for couple days. I have another question, is there a minimum bed thickness for floor tiles to stop height being raised too much. They are going on to hardie backer
How long have you been tiling @Ivan Rubery
Hi, well. I have done a few jobs, tiling not my main area probably about 1 year. I have a large floor trowel with a 10mm half moon recess which i would always use on a floor, however, trying to keep floor height to minimum, just thought i would ask the question if a thinner bed such as 6mm would be an option. I realise tiles on floor need good contact, due to them being stood on and weight bearing down such as toilet pans and people. Thanks
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
