Discuss granfix wall grout 10kg bags (danger) in the British & UK Tiling Forum area at TilersForums.com.
Burnsy
lots of products these days use water as a base for water proofing
sorry mis read your question
Well you learn something new every day!
Have you got any examples?
Do you mean neat water mixed with something can waterproof or water as part of the liquid base that that helps waterproofing?
I was talking about grout mixed with clean water only
doug boardley
It wasnt an answer, it was a question :lol:
Enlighten me as Im not sure
because when water is mixed with cement, the whole chemical composition changes. Imagine mixing your addy with your whisk rotating clockwise, if you then mix it counter clockwise it doesn't revert back to water and powder does it:smilewinkgrin:
stevee
i use granfix grout regular,the white is a nice clean bright white ,and its sys on the bag for swimming pools, this gives the chance of a photo opportunity:lol::lol:
granfix grout
ozboz
Gotta say I'm not keen on granfix, Mapei Man now, Top products and top tech help and back up. I refused to use granfix grout on a granite job last year, the shopfitters director copped a serve from the supplier who phoned granfix, some one at granfix informed us that 90% of the trade uses granfix ?!! I began to wonder what the other 10% uses !! Anyway I got my own way, they came up with norcross light grey flexible, gotta say it was xlnt! real easy to spread and wash off ,3mm joints 15 mm thick exfoliated black granite, about 200m2 in all Sorted !
Mike
This is the first post by this member and at least 3 of the replies have contained comments bordering on churlish and 1 removed by administration.
I'am sure even a regular contributor would find the tone unacceptable and wonder what's the point of posting.
If you haven't got anything constructive/helpful/amusing to add why bother.
This is my opinion of this threads content.
I was taught that no grout was waterproof just water resistent, hence the requirement of tanking shower areas. if the grout fails and water gets behind the tile then the tiles are likely to fall off due to possible substrate damage or tubbed addy breaking down due to the addy getting soaked. I always use granfix with no problems but i always tank the walls. only takes half an hour with a roller!
Richard Edwards
Hello
I've read all the posts on this subject and all through, almost to the end, some members have been asking for further info on preparation, adhesive, grout and installation method used. - Clearly either, you have not done something correctly in the prep, or used in appropriate products for the application, or maybe the product failed due to manufacturing, storage or specification.
Good folks like John and others have all tried to help and asked a variety of questions, aimed at trying to understand what has gone wrong. Mostly its because they want to help and partially its because some of us use Granfix products from time to time - [as we do] and we try to gather as much info as we can to avoid similar issues.
I do not use the adhesive that you have used, however it is probably a premixed water disperstion gypsum based addy. Could you please supply some more info on the application / prep / substrate etc
1 What substrate did you tile on to. was it sound etc - type ? ?
2 Was the shower wet area tanked and if so what with ?
3 Are my assumptions re the addy correct - If not please correct ?
4 What was the time scale / weather-humidity etc between tiling and Grouting ?
One thing for certain, pre-mixed addy is not waterproof or suitable for showers / wet areas - Only use cement based product.
Tanking is critical - no tanking - no waterproofing
And finally - All grout [except Epoxy] will let water through - although adding polymers and SBR etc will stop some water ingress, and if you have used water dispersion type addy, then after a short time, if water leaks through the grouting, the adhesive will revert back to a soggy dough - ie similar to the state it was it the tub, and heh-presto your tiles fall off.
Hope you will be able to help us with some more info Mr VP Proddy - We look forward to your reply post etc
Thank you
Reply to granfix wall grout 10kg bags (danger) in the British & UK Tiling Forum area at TilersForums.com
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
  • Sticky
Any one out there had or are having a problem with soft grout. Grouted a bathroom (walls) with...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
