Guest viewing is limited
Granite Tiling - Sealing the Grout ?
I havnt used epoxy on granite but if it is that polished, I dont see why you would have a problem. Iv only used the Mapei Kepapoxy and its fine to work with and gives a lovely finish that wont stain. Its just knowing that it is different to work with than cement based grout. If you go down that route, stick a post up and get as much info from the experts on here as poss.
As for the spray sealers, I have used Seal guard in the past and strangly enough I used the LTP for the first time today. Very little between them, they both seem to work and both seem easy to use but to be honest I dont like using them. There is a lot of wastage and feels a bit messy. I will go back to using Lithofin grout guard again, you paint it over the joints with a fine brush. Takes longer but I just like it.
