Discuss grouting metal listello trims in the DIY Tiling Forum area at TilersForums.com.
Sean Kelly
1,068
Ruislip
Some chrome trim have a clear protective wrapper that peels off after grouting. I am assuming yours doesn't. Make sure you use a fine grout. I personally use Ardex FS grout (comes in about 32 different colours available from CTD (aka Tile Depot). However, test your grout on a small piece of off cut trim before you commence grouting. Make sure it's wall grout (as this contains much finer sand). Floor grout contains thicker sand and will deffo scratch your chrome.
Don't let the grout sit on the trim any longer than it has to. i.e. wipe off any excess with a damp microfibre cloth and buff up with a dry one.
Realistically, the chances are you will not damage your trim as long as you don't wipe acid on it!
F
Frenchdc
I have bought some Larsen Colour Fast 360 Flexible Wall & Floor Grout, is that any good?
Sean Kelly
1,068
Ruislip
Never used Larsen but 'Wall & Floor' might be a clue!
Wall grout is normally smooth.
Floor grout is normally very sandy.
I personally stick to wall grout for walls because floor grout is:
1. Sandy (coarse).
2. Because of the sand it is normally a heavier grout and most of it ends up on the floor!
Someone will come back with a definitive answer to your Larsen grout.
Reply to grouting metal listello trims in the DIY Tiling Forum area at TilersForums.com
Hi, hoping someone can help with advice. We purchased 600 x 600 tiles for our bathroom floor...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
DIY Tiling Forum
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
