Brinkley
on paper faced you grout first then fix then soak the paper and peel it off usually get holes in the grout through water ingress hence grout w hen fixed as well also removes glue on the surface that paper was stuck with
Discuss Grouting mosaic sheets prior to installation? in the UK Tiling Forum area at TilersForums.com.
mg would you grout a mosaic ceramic tile before grouting?? i wouldnt
Reply to Grouting mosaic sheets prior to installation? in the UK Tiling Forum area at TilersForums.com
