Discuss hacked off with battens in the UK Tiling Forum area at TilersForums.com.
geordie2013
:icon8: Totally naffed off tiling three months a half dozen jobs later i just cant get my battens level. Whenever tiles meet again after tilig 4 walls they never meet. Spend about hour trying and failing to get the next wall on the same level as the last. Help gratefully appreciated.
Also am i the only person who cant stand joiners telling you how to do your job. C'+@k.
Thanx
F
Fekin
For a full bathroom I always batten 2 walls first going on a right angle, keeping a spirit level on the first so I know it's level.
Then line up by eye the second batton, stick it, get the spirit level on it and the other batton across the corner and get it level and that's it, 2 battons across 2 walls on a 90 degree both level to eachother, then as you go onto the 3rd wall do the same, and in my view you can't go wrong.
shaunykieron
yeah put a level line round the room and stick to that , say if you come off the bath full tile (depending if its ok with reguards to your cuts) then level round the rest of your room , i always finish above the door so if it is slightly out for whatever reason then its in the best place to hade it
shaun....
Caledonian Tiling
Geordie,
Make a datum line approx half height of your room and use this as the central
point to refer to on marking out your room, taking in windows,doors,baths etc
ensuring full or as full a cut as possible when meeting each feature.
Based on you have all marked out correctly, tile fom your datum line down
to the floor, take this all around your room, be easier to identify/correct any
issues on your tiles matching up. Once done the rest should just fall into place.
Unless large format tiles stick to a high grab(supergrip) adhesive.
Then take your battens attach a piece of chain inbetween them and
give your know it all joiner some bruce lee nunchaka action to
his big mouth...... you will have no more problems with him im sure....
Caledonian.
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
Stick a level datum line around the room at any possible height where it's most constant, so not in the way of any boxing in and windows if possible, then when you find your starting point after working out the best looking cuts you can use a tape measure to measure down from your datum line around the room to stick on your battens. I used to just batten one wall at a time too, although I don't know if that would help, it was just easier to do and used less wood.
Tip: Spin the level around each time you draw a line down the length of it to counter-balance any few mm it's out. A level that is 2mm out will be 20mm out once you've used it 10 times. Spinning it each time you use it can only give you 2mm or less inaccuracy.
V
Varley
How much did you pay for your spirit level?
You need to be buying good gear and spirit levels should always tell you what there acuracy are, I have stanley levels and they are accurate up to 0.5mm per metre, thats a good level but they cost £35.00 each. Don't go buying 5ft levels for a fiver, they'll be miles out.
Reply to hacked off with battens in the UK Tiling Forum area at TilersForums.com
Newbie member here. I've checked the threads and I can't see the answer to this one elsewhere...
11K
Jelthetiler
Hi guys, need some advice on leveling a kitchen floor. job is 8 square metre floor to tile with...
5K
Hi,I would appreciate any help confirming the final steps for my wet room project, please (see...
5K
ojtiler
At what point do you say no to doing a job ? My problem here is this, I get called in to quote a...
F
Hi, DIYer here and trying to work out my best solution for tiling around a drop in tub with an...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
