Hairline crack repair advice
Hi All. Thanks for the replies so far.
The tiling was done 4 or 5 months ago as part of a large renovation project. We had no say on who the tiler is but we did make sure to the best of our knowledge that some things were done correctly.
For example, the floor is a suspended floor but we had the builders completely rebuild it with new joists and supports under the joists to remove any deflection to the absolute minimum. It was rock solid with supports every 1.5m. We used Mapei flexi adhesive, matting and the floor was as perfectly level as possible. The tile manufacturer actually sent a rep (Italian company whose name escapes me) to do with another matter and he checked everything and said it was all done perfectly (up to that point)
Now, i know for a fact that there is sufficient gap all round the area and we have done the calculations exactly according to the manufacturers recommendations. We even had to put a gap in the actual area to allow for expansion as the area is quite large.
Did they drill the corners? Well i have to put my hands up and say i have no idea. I did not check as it was not something i was aware of. May I ask, is it true to say that this is something that ALL tilers worth their salt would do? sounds like such a good idea but i genuinely never heard of it before and I have even frequented these forums several times in the past.
Now, for the problem at hand. I am a little stuck here as I am very reluctant to change the tile. Firstly because we used Epoxy grout (Kerpoxy i think) and secondly because we have a wet underfloor system and im concerned about some numpty damaging that which would be a disaster. So, has anyone heard of this infiltrating epoxy before? anyone used it in the manner im suggesting? Its surely worth a go?
edit - re vertical gap. Also not something i was aware of. Manufacturers datasheet only mentioned lateral expansion.
IMO filling it with a resin will only highlight it even more unless you are willing to sand it smooth but then you damage the finish of tile so if you are not going to take it out and replace just fill in with a colour match grout or Silicon, just papering over cracks tho
Yes there are epoxy resins available to do what you want, the name escapes me at this moment, but they are available.
Check the Waters group based in Liskard, try and speak with Daniel Waters (I won’t state the obvious)
If they can guide you, they will.
Ok question answered.
I agree with the above.
Cardinal sin with thin tile, not drilling corners of any cut out.
By Creating an arc in the corner it helps eliminate the risk of this kind of breakage, there’s no actually staring point for a fracture, and it’s naturally stronger.
However, it won’t be the sole cause, some other issue outside of this oversight, has actually attributed to the problem.
Something has stressed the corner, and as a bi product of that the tile has fractured, that’s what you need to determine.
Expansion of architrave and skirtings are prime suspects, as are un-noticed high points on an external corner of a screed.
Any or all of these are just some of the reasons the corner became stressed.
It sounds like you paid for an high end service, and you may well have received it.
Unfortunately as fixers we can only carry out our tasks to the best of our ability, and hope we spot all the potential pitfalls, occasionally something goes unnoticed.
Epoxy grout can be softened with a heat gun, it can be removed.
You should be able to remove the slab without any damage to the substrate or wet ufh, unless if it’s a retrofit ufh system.
It will then be down to the installation of your floor and the method used. This can determine the level of risk to your heating.
As far as numpty’s go....... can’t guarantee against them I’m afraid, 😀
If you’re careful who you hire, I’m sure you can sort the men from the boys, you’re an intelligent guy.
Looking at that slab again, I think a good ‘Magic Man’ could sort that, it certainly has enough movement in it to blend fairly well, as long as it’s not highly polished.
If it is, it’s highly unlikely that it can be hidden.
Still the holy grail I’m afraid.
Good luck.
Again, thanks for the replies. Callatiler, im not concerned about the appearance that that is NOT the motivation behind this suggestion. My only concern is to strengthen the crack so A. it does not get any bigger and B. may reduce the necessity to have the tile removed/replaced..
My question is, does my proposed action strengthen and fixes the tile from a movement/structure point of view? My fear is that as people and one rather large dog walk on the tile, it will start moving and become worst with time. I stress again. I dont care how it looks at this point in time. Its in a place that is quite hidden and im confident that i can make the crack much less visible later if needed.
3_fall - thats good to hear. I do have a spare tile off cut in the garage that will fit there if it comes to it. I will also do some checking on your suggestion regarding the Waters group. Really appreciate your help with this.
Is there anyone on this forum that is an expert with this type of situation? We may need to get someone here to asses the situation and if necessary fix the tile.
Had a chat with the Waters group. Incredibly helpful so thanks for the advice 3_fall. Gave me two possible products to look at. One is this: Integra Adhesives - http://www.integra-adhesives.com/ which is incredibly strong but may not be fluid enough for my needs and the other is this Imprepox Premium – Bellinzoni Srl - https://www.bellinzoni.com/cms/en/prodotti/epoxy-adhesives/imprepox-premium-2/ which sounds like its exactly what im looking for. Only problem is they dont have it in stock at the moment but they are chasing a tin for me as we speak.
Thanks again everyone. Ill update this thread with how i got on when its done.
It’s a shame in a way that it’s noyhing more than a hairline crack, if it’d been something a little more, the Integra would have worked well, not only is it designed to repair lateral cracks in slabs but it comes in 309 colours, colourmatching the slab with 2 or 3 different tubes could possibly have masked it altogether.
Turn on you under floor heating and the gap will open slightly wider Mapei have a resin called epojet which is low viscose and penetrates as you say , fill the crack with resin until it won't take any more , then turn your heating off for as the floor cools the gap will close slightly it may well close enough for the gap to become invisible , I have one on my kitchen floor which cannot be seen until the UFH is turned on and run for a few hours , same thing the tile was not drilled out when the check was cut out and I was at in hospital at the time it was tiled so could not do the floor myself
That looks like good stuff never seen that brand before is that what u fill ur mites with ?
Shai,
Shai,
Shai,
Shai,
