Discuss Hairline cracks in terracotta tiles that is seeping some sort of dark brown oil in the Canada Tile Advice area at TilersForums.com.
Guy,
I am not involved in this business at all, so I would appreciate any help or advice pls. I have noticed very recently that hairline cracks in my kitchen floor have started to seep a dark brown, sticky oil. There has been no spillages, so it is a complete mystery. The tile isn't lifting - I'm wondering if the chipboard has somehow started to rot - having googled it I've found that chipboard is made with linseed oil - obviously I need to stop this as we are treading oil into other rooms - many thanks in anticipation for your help in this matter -
Cheers
John
Hi Tony, I say chipboard, but I'm guessing tbh - the floor was laid 12 - 15 years ago and we have never had a problem - there is no movement in our area and the tiles are lifting - the cracks I think are probably wear and tear - I've attached pictures showing the oil
Cheers for your help - much appreciated.
[automerge]1569141796[/automerge]
Tiles aren't lifting
Dumbo
You're tiles look like terracotta coloured ceramics .
There is no moisture in your tiles .
There shouldn't be any moisture in your subfloor . You have something going on .
Go into a builders merchant and feel some chipboard and feel some ply , it is dry , moisture is being generated . Unless it's your washing water coming back up through .
Reply to Hairline cracks in terracotta tiles that is seeping some sort of dark brown oil in the Canada Tile Advice area at TilersForums.com
In short: would using some expanding foam behind 2 tiles that have a small amount of flex, where...
5K
23K
Deleted member 57709
Hi All, We have just discovered a hairline crack in one of our 6mm italian porcelain tiles. Its...
26K
I would just like to see if anyone could give me any advice on why this may be happening with...
6K
Hi everyone, I’m looking for a bit of help please. My house was a new build 18 months ago and...
6K
J Sid
DA74PX
What member type are you?
  1. Floor Fitter
Business Name
PDA
    Votes: 9 6.1%
    Votes: 14 9.5%
    Votes: 11 7.4%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 18 12.2%
    Votes: 15 10.1%
    Votes: 7 4.7%
