Discuss Hardiebacker in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
You do not Dab Hardi backer...:ninja:
HardieBacker EN installation 200810 masonry walls.pdf
H
harry
thanks dave wasnt aware of that, 6mm notched trowel is no good for this job as its an old property and the walls are all over the place ! hence why i was going to dab them, whats the max kg per m2 on bare plasterboard ? i was hoping to fix travertine 410 x300 to my shower area in my property that I`m renovating ,
thanks.
H
harry
32 kg inc addy and grout.
Weigh a mtr of tiles and add 3 to 4 kg for adhesive and grout.
cheers Dave, also when I mentioned dabbing the hardibacker I was going to use drywall adhesive that plasteres use to dab boards as we all know how hard that sets and then add some additional screws...
DHTiling
I can only say what hardibacker passed onto me..I cannot say whether your method will be ok..:thumbsup: as the dry wall normally sticks to the paper lining of plasterboard and not cement boards..
H
harry
The reason being it was'nt designed for the purpose, dry wall adhesive is for gypsum boards even certain metal systems.
You may get a reaction between the two materials which cause a failure if moisture penetrates the gypsum and cement.
Thanks for all your replies and info, due to the bare brick work been very uneven ( 120 yr old house ) so a full bed of adhesive is not possible, i think I will have to dab it out with plasterboard and then fit a homelux tanking kit ..:thumbsup:
Reply to Hardiebacker in the British & UK Tiling Forum area at TilersForums.com
Hi all what adhesive would you recommend for dot and dabbing foam cored backer board onto...
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
I've had a look through threads but cannot find anything on this. Lots of info on commissioning...
Hardiebacker
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
